Author Topic: New version of program for usb programming interface?  (Read 36896 times)
Offline Lu.Sochr
« on: July 24, 2012, 05:22:52 PM »
Hi Guys,
I wanted to change some settings in my external magic controller and when I downloaded needed program from goldenmotor, I noticed that there is new version of it and there is new setting called "acceleration". I included printscreen.
Any clue what this setting does?
Mongoose Salvo Sport 2012 with 901 Pro Kit and 36V15Ah LiFePo4
Re: New version of program for usb programming interface?
« Reply #1 on: July 25, 2012, 02:11:18 AM »
Hi Lubos,
I think the acceleration function controls how quickly the motor responds to the throttle movement to produce a softer/smoother acceleration.
Where did you download the V1.1 software from? I just checked the GM site and all the links I found were for the earlier V1.0. ???
« Last Edit: June 14, 2024, 03:51:41 PM by Bikemad »
Offline Lu.Sochr
« Reply #2 on: July 25, 2012, 12:37:15 PM »
thanks for your reply. So if I understood this right, it should control throttle delay right?
If I downloaded 1.0 version from goldenmotor.com I noticed there is column called "RPM" on place instead of "acceleration" I suppose it would mean the same thing right?
I downloaded 1.1 version from our czech vendor webpages, here is the link: http://www.e-pohon.cz/fotky4744/fotov/_ps_72Magic_controller_USB_soft.zip
I thought they would have this version directly from goldenmotor.com, but it seems they do not!
My previous old version did not have setting "acceleration" nor "RPM" at all.
« Reply #3 on: July 26, 2012, 11:23:39 AM »
Thanks for that link, the updated program seems to be a lot less temperamental than the previous version.
I'll try programming my MPIII with this latest program when I get some spare time to see what difference the settings make.
I also noticed there are a couple of other new settings too; motor direction and sound.
This would make it a lot easier to reverse the motor direction for certain applications, and it might also be an easy solution to stop the beeping in reverse that Myrek experienced.
I wonder why GM have not updated the software download on their site? ???
« Last Edit: July 26, 2013, 11:42:12 PM by Bikemad »
