Author Topic: Magic Pie loses all power under load at low speed  (Read 28729 times)
Offline Trond Jacobsen
Re: Magic Pie loses all power under load at low speed
« Reply #30 on: January 15, 2011, 03:46:17 PM »
Trond=Trond Jacobsen. Suddenly not able to log on. Needed new log in.
« Reply #31 on: January 15, 2011, 04:11:10 PM »
Hmmm another person losing their account :(
I wonder if there is a maximum set.
I'm probably next lol
Re: User accounts gone missing
« Reply #32 on: January 15, 2011, 04:22:32 PM »
Welcome back Trond, unfortunately as MM already mentioned, you're not the only member who has lost their account.
I've been trying hard to find out how more than a dozen user accounts could have disappeared for no apparent reason during the past 4 or 5 days, but I cannot find any logical explanation for their disappearance.
If it was caused by Gremlins, I hope they've gone and don't come back again.
« Last Edit: January 15, 2011, 04:50:23 PM by Bikemad »
Offline Cornelius
  • Grimstad, Norway
« Reply #33 on: January 15, 2011, 04:43:42 PM »
Except gremlins, check who's got admin/account related rights... :)
« Reply #34 on: January 16, 2011, 09:59:06 AM »
Has enyone bought seperate internal controller from GM? How do I do that? What price?
« Reply #35 on: January 16, 2011, 01:04:26 PM »
i think they are about $33.00 USD on the GM website with the option to pay with Paypal, but then you will have see what postage they want to charge. go to the paypal checkout and it will tell you postage cost.
« Reply #36 on: January 16, 2011, 01:45:43 PM »
The $33 "PI-0200I internal" on the website refers to the USB Programming Interface cable, not the controller itself.
I suggest you email sales@goldenmotor.com (or possibly tom@goldenmotor.com) and request a price for a replacement internal controller for the Magic Pie.
Offline pediman
« Reply #37 on: January 16, 2011, 03:02:46 PM »
Exact same problem on my Pedicab with one month old 901 front hub using the Golden Lithium Battery 36V16A. Tried two different Anderson connectors, but problem remains.
Specifically, on start (even without load) motor cuts out if throttle is opened quickly. After about five seconds will work if throttle is opened very gradually.
Once in motion, motor cuts out under load (hills) at low speed. After about five seconds it will work if load is decreased either by peddling hard first or changing gradient.
« Last Edit: January 16, 2011, 03:13:01 PM by pediman »
« Reply #38 on: January 16, 2011, 05:18:30 PM »
Yes, same problem. Please post if you find a solution. I will. I will send email to GM about buying controller.
« Reply #39 on: January 16, 2011, 05:22:56 PM »
Hi Pediman
Perhaps you should also contact Tom if you have not done so already.
The controller low voltage cutout would turn back on automatically, so if you are resetting to get the power back it sounds like the battery BMS is cutting out.
What voltage do you read from your battery terminal?
Email Tom tom@goldenmotor.com and explain you are experiencing this and steps to take next as you may need to test your cells.
I'm sure your pedicab customers would be wondering whats going on when the power cuts in and out!
good luck
« Reply #40 on: January 16, 2011, 05:51:20 PM »
Hello Pediman
Maybe this theory has already been floated but it sounds like a 36 volt battery running a controller set at 48v. Do you have a USB cable?
« Reply #41 on: January 18, 2011, 05:36:36 PM »
No answer from GM. Considering Infineon 40. Easy to install? Does the Infineon need programing to work with MagicPie?
« Reply #42 on: January 18, 2011, 07:55:46 PM »
Sorry about that,  I miss read the GM website
Re: Fitting an alternative controller
« Reply #43 on: January 19, 2011, 01:26:26 AM »
More useful information can be found here regarding the conversion from internal to external controller on the Magic Pie.
The Infineon controller does not need to be programmed to work with the Pie!
« Reply #44 on: January 19, 2011, 07:34:02 AM »
i really hope internal controllers are available to purchase ???   I now have two of them, and am prepared and am slowly working upon my skills and understanding to eventually change one if neccessary.
