Author Topic: Problem posting images  (Read 29295 times)
genroxbro
  • Guest
« on: August 04, 2009, 05:45:41 PM »
Tried the search engine but still can not find a solution.
My problem is when I click on the image button and try to insert an image into an article, the thumbnails of the images that appear are like frozen can not click on them. Does anyone know why that happens?
« Last Edit: August 26, 2009, 09:33:48 AM by Bikemad »
  • Merry Christmas
Re: Problem posting images
« Reply #1 on: August 04, 2009, 09:41:11 PM »
When you use the Insert Image button, it inserts an "image" into the post.
(Which is usually hosted on another site/web server)
It does not use a hyperlink with the image, therefore you will not get any response by clicking on it.
To link an image using a hyperlink requires special coding.
Using "Insert Image" button:                  Image used within a modified hyperlink:
Click on the images above to see the difference.
I guess that's what you meant.
« Last Edit: August 04, 2009, 10:27:10 PM by Bikemad »
« Reply #2 on: August 04, 2009, 10:26:52 PM »
Yes, the Image Tag is an html editor function where you can put an image url
for a picture on the web, like .
If you want to include an image with your post, then use the 'additional options' and browse
to the image on your computer.
By the way, since this is a new account we will be watching to see if you post spam
images and your account will be suspended in a heartbeat.
