Author Topic: Controller Power Limit?  (Read 53335 times)
Offline GrandeDan
« on: March 03, 2025, 01:40:04 PM »
Hi All,
I recently had a problem with my motors throttle system. I am using a 5kw BLDC motor and a potentiometer as a throttle. I was using my motor for about 30 minutes just fine. Went to do something else and when I came back a few hours later to use the motor again, I had low power.
My bus amp limit set on my EzKontroller was 92 amps and I was only seeing 35.
The motor and controller were not overheated as it had just sat for hours and never got hot during the first use time.
As I was trying to troubleshoot, I had the throttle at full power, it started to rise from 35 amps up to my limit of 92 amps out of no where.
My ultimate question is, was this a controller limit that I am unaware of with EzKontroller or was this most likely an issue with my potentiometer?
TYIA
Offline GrandeDan
Re: Controller Power Limit?
« Reply #1 on: March 03, 2025, 02:28:50 PM »
I should add that the controller model is EZ-A48500
