Author Topic: Magic Pie rotor and Stator Improvements?  (Read 49352 times)
Offline Grasshopper
« on: August 13, 2024, 11:15:14 AM »
Are the basic rotors and stators the same for all Magic Pie motors since inception?  My project requires a custom shaft and bearing setup as well as the supporting parts so changes to those are not important.  The controller will be mounted externally.
The basic magnet and stator rings will be mounted to a custom rim and hub but I want to use the best setup for high amps at 52v.
