Author Topic: 5kw motor jitters after Hall Sensor replacement  (Read 38227 times)
Offline Filekidb
« on: February 03, 2024, 05:21:25 PM »
hey im will trying to pose about air cooled 5kw motor... I recentlly had to replace  the hall sensor in it and after putting it together it works until I PUT a load on the motor then it just jitters. no tourque. thoughts???
Re: 5kw motor jitters after Hall Sensor replacement
« Reply #1 on: February 09, 2024, 12:05:40 AM »
Did you replace all three Hall Sensors with Honeywell SS41 Hall Sensors?
If you used different Hall Sensors, it is possible that they may operate differently to the original ones.
Hall Sensors can also be damaged if heat from the soldering iron is applied for too long.
Use a voltmeter to check the operation of all three Hall Sensors to confirm they are all working correctly.
Take a look at this post and this video for more details on testing the operation of the hall sensors.
