Author Topic: Pinout VEC200  (Read 51296 times)
Offline Black.ghost.off
Pinout VEC200
« on: October 11, 2023, 02:03:07 PM »
As far as I can see, the VEC200 does not use a standard 3*10 connector.
1) Who can I contact to buy one of these wholesale and retail if needed?
2) Where can I find the pinout for it?
Re: Pinout VEC200
« Reply #1 on: October 11, 2023, 05:24:40 PM »
Unfortunately, I don't know where you can obtain these connectors, perhaps GM in China may be able to help (sales@goldenmotor.com).
As far as the pinout details are concerned, the Vector controller wiring diagram shows the important wiring connections on the 30 pin connector:
The pin numbers when viewed from the wiring side of the plug are as shown below:
I also found a pinout diagram for a LingBo Controller which appears to be very similar to the VEC200 controller:
Click on images to enlarge.
Hopefully you can find the information you are looking for from the above diagrams.
Re: Pinout VEC200
« Reply #2 on: October 12, 2023, 02:48:56 PM »
Perhaps somewhere there will be a more detailed description of the contacts (voltage, maximum current per contact, how to understand that CAN is available, description of CAN if it is available). Unfortunately, there are very, very few datasheets and information about this driver (and about BAC0501 too), so we have to learn a lot by experimenting.
