Author Topic: Brake by reversing  (Read 172898 times)
Offline Pontus
    • Grinde 19
Brake by reversing
« on: September 02, 2023, 07:44:03 PM »
Last years folding propeller was swapped out for a one with 3 fixed blades, in order to to get re-gen working.
This means the propeller is often coasting along, even at slow speeds inside harbours for example. Manoeuvring a 4 T sailboat in tight places often requires shorts burst of high thrust, in order to get a good amount if water flowing past the rudder for steering. This also implies rapid shifting between forward and reverse.
What I've noticed is that the motor wont start in another direction than the one it's coasting in, i.e. if the boat make speed through the water going forward coasting, it cannot be started in reverse in order to brake. Even worse, the controller seems to stop and needs to be power cycled in order to start. Stopping the propshaft by hand makes it possible to run in reverse. The exact same happens the other way around; I cannot run forward if the prop is coasting by the boat moving backwards.
In a land based vehicle this is of course a desired behaviour, but on a boat that's obviously not the case This is not only annoying but downright dangerous.
I first thought it was possible to solve this by increasing the stall protection time and/or increase start current of the controller. But even with 4 s stall protection time and 150 A as starting current it simply cannot be started in the other direction.
Is there a setting for this that I might have missed? Without a solution, this is an absolute showstopper.
« Last Edit: September 03, 2023, 12:42:17 PM by Pontus »
Follow along my electric conversion of a 4 ton Danish sail boat. Grinde 19
Re: Brake by reversing
« Reply #1 on: September 02, 2023, 09:38:50 PM »
Unfortunately, I am not aware of any programmable setting for the VEC controllers that would have any real effect upon this particular problem.
It could be that your propeller diameter or pitch is simply too large for direct drive with this motor, as the starting torque of the motor appears to insufficient to overcome the amount of torque being produced by the spinning propshaft while the boat is coasting.
Think of it in terms of a car whose gearing is too high to allow adequate engine braking on hills and also stalls easily while trying to pull away because the high gearing cannot apply sufficient torque to the wheels when trying to take off from a standstill.
I don't know whether the EBS Auto-Mode is supposed to work with a boat type throttle in the Neutral position, but I seem to recall that the manually switched regenerative braking only works when the motor is spinning in the default forward direction of rotation, as it does not work if the motor is running in the switched Reverse direction.
Do you know what the lowest rpm value is that the EBS Auto_Mode Speed (rpm) setting will accept?
Do you have access to a smaller diameter and/or reduced pitch propeller you could temporarily fit to see what difference it makes to the low speed forward/reverse manoeuvring?
If you don't experience the same problem with a smaller propeller, then adding the correct gear reduction to the existing propeller may hopefully cure the problem as well.
Offline Pontus
    • Grinde 19
« Reply #2 on: September 03, 2023, 12:35:25 PM »
Both the diameter and pitch is in line with boat speed and rpm. After some more testing it seems the motor not even tries starting when it's coasting in the opposite direction, like there's a built stop that not even lets you try reverse to brake. Also, the motor won't start after a power cycle if the prop is coasting when the controller starts, regardless of direction.
I'm not sure what the lowest value for EBS-auto is but 120 rpm is ok. I haven't got EBS-auto to work any way.
I did however got the following reply from GM, which feels like a real bummer.  :(
Please swap to our new controller with new throttle .
You old set doesnt fit boat at all .
« Last Edit: September 03, 2023, 12:47:03 PM by Pontus »
Offline Defuzo
« Reply #3 on: September 03, 2023, 02:25:52 PM »
VEC controller? not tobe confused with the Vesc-project (opensource controllers)?
I have similar issues with MP2 (ebike hubmotor), I can run it in reverse. But if I touch that button while running forwards, I haveto come to complete stop, before going in ether direction. (had to change the parameter for regen-break to 80%, because my 36v battery became overloaded, -so thats not the solution)
« Reply #4 on: September 03, 2023, 06:16:27 PM »
That's definitely not what you wanted to hear.  :(
Perhaps you could rig up some form of mechanical brake on the propshaft that could be temporarily engaged in the Neutral position during manoeuvres.
Whilst I appreciate this is not an ideal solution, it should be a lot cheaper than replacing the controller and throttle, and perhaps it could be activated by an electrical solenoid controlled by a microswitch on the throttle mechanism to automatically engage the brake in the Neutral position.
You could then add a simple change over switch (Regen switch) to automatically disable the propshaft brake and enable the Regenerative braking simultaneously, as you wouldn't want both activated at the same time.  :o
I was referring to the programmable settings in the PI800 software relating to the Golden Motor Vector controllers (VEC200, VEC300 and VEC500 etc.) :
The original version of the PD-280 programming software for the non-vector Magic Pie controllers had an option to select "Immed" or "Unimm" for the reverse mode:
However, I am unable to try this function out as I don't have the Reverse wires connected on any of my Magic/Smart Pies and this software does not work with the MP4 and MP5 vector controllers.
I presume that the "Unimm"  option will only allow Reverse to be activated after the wheel has stopped turning in the forwards direction, whereas the "Immed" option would presumably select Reverse Immediately without waiting for the wheel to stop.
I did however post a very poor quality video on YouTube over eleven years ago demonstrating the basic operation of the reverse function on my MPIII motor, but at that time I didn't have a programming cable suitable for the MPIII to try out the different Reverse modes. Unfortunately, the USB programming cable I had for the Original Magic Pie and later MPII did not fit the connector on the MPIII's newer style harness.
The Miromax version of the PD-280 software also allowed the motor direction to be changed, the Reverse Sound to be turned On or Off, and the Regenerative braking could be set right up to 116% instead of 100%:
The reverse sound only worked on later MPI & MPII internal controllers equipped with a beeper and some BAC-281P external controllers.
Offline Pontus
    • Grinde 19
« Reply #5 on: September 13, 2023, 10:55:35 AM »
Although it might be possible with such a braking arrangement, it's not a path I'm willing to go. It ads complexity and several more points of failure.
If GM is right in their answer, which is not 100% clear due to both things getting lost in translation and the fact that they of course would like to sell me a new controller - then it's a fault by design.
The answer I was hoping for would be a firmware update, since all this is software settings inside the controller.
If not possible, my best hope is a refund for the current controller and buy a new one.
But I'm still curious if no one else have had this problem! Throwing forward & reverse is more or less standard procedure in harbour manoeuvres. Am I the only one with this experience? What's setting my installation apart from others?
Offline Sventropy
« Reply #6 on: October 29, 2023, 04:51:59 PM »
Pontus, I haven’t had that exact problem. In fact sometimes, I put it in reverse while sailing to stop the prop from rotating because the noise can be annoying. Though I have had an issue at times with it not starting. I can’t quite isolate the situation that causes it. Sometimes after I’ve been motoring hard and stop for a second (to drop fenders or something before making the turn into my marina) it won’t restart for a minute. And sometimes when it’s auto-rotating really fast it won’t restart for a moment, then suddenly start up at whatever speed I’ve left the throttle in. This last bit has happened a couple times while fighting the current to sail under a bridge. Not fun.
I’ve wondered if heat has been an issue. When you stop the air cooled motor is no longer cooling so the temperature might peak then take a second to cool down. Though this only explains the first scenario and not the second.
Have you made any improvements?
Also I haven’t really been able to get the regeneration to work.
Offline BjornO
« Reply #7 on: November 17, 2023, 09:11:39 PM »
Hi, I have the same problem when going from forward to reverse.
The first version of the speed control box was just a potentiometer. However, it became more unstable during the summer.
The second version had a multi-position rotary switch, and a separate switch to the brake input on the controller. It worked better, but as I also changed a lot of controller parameters, I don’t know why.
I an currently planning version 3 of the speed control box. This time I will put a switch on the throttle lever that automatically engages the brake signal when the lever is in its neutral position.
/Björn
Offline Fabio
« Reply #8 on: February 10, 2024, 09:27:58 AM »
hi, I had the same problem and I changed the regenerative bracking option and now I can start the motor forward or reverse also if the propeller is turning in the other side, i'm still testing to real understand how it work.
Offline Pontus
    • Grinde 19
« Reply #9 on: June 04, 2024, 07:26:53 AM »
Here's a short follow up on how this issue has developed.
My European GM reseller Vela Solutions replaced the VEC 500 for a EZ Kontrol - free of charge! They also supplied the, a bit ugly though quite sturdy, GM Throttle.
Initial test show no sign of last year's issue. There's no problem doing quick changes between forward and reverse, even when the motor is still coasting.
More testing is needed though, since I haven't tried to brake att higher speeds yet, like when sailing.
Offline TommiS
« Reply #10 on: June 14, 2024, 06:04:51 AM »
Vec500...try turning throttle to 0-position (12 o'clock). Then e-lock off and again on. Then try to reverse. This works in my solution.
Offline Pontus
    • Grinde 19
« Reply #11 on: June 17, 2024, 06:13:48 AM »
Needing to do that kind of a manoeuvre in order to brake sounds like a recipe for disaster when trying to dock in bad weather.
Offline Polar
« Reply #12 on: May 12, 2025, 12:15:37 PM »
For future boatowners experiencing this: I can confirm the above. Coasting keeps the shaft spinning. Vec controllers won't allow reversing when the shaft is still spinning. It almost has to stop or stop totally.
I replaced my vec controller with an ezkontrol version.
Now I can brake by reversing at any speed (boat has a max of 11km/h). Docking has never been so simple when you come of a diesel. Very quick response in shifting forward-reverse and back
Tested over a longer period. Very happy with it.
I have a belt driven setup. I wondered if the belt would skip teeth when going from forward to reverse but it holds up.
Don't bother trying mechanical or e-lock braking. The extra operation takes too much time. Biting the bullet and switching to an ezkontrol has been my perfect sollution.
Offline Pontus
    • Grinde 19
« Reply #13 on: May 12, 2025, 12:51:18 PM »
Yes I can confirm the above as well.
I replaced my VEC for an EZkontroll last year and, as said, docking has never been as easy as now.
It's actually a game changer to be able to go full throttle for 1/2 second in order to manoeuvre the boat rather then accelerating.
Offline Johnculley
« Reply #14 on: May 17, 2025, 08:28:06 PM »
Hi Pontus. Which throttle are you using ? I have the TRC012 and was told by GM to connect all the cables. Several of them don’t fit as the plugs don’t match but the motor seems to work ok. (A bit of “shuddering” at certain revs but everything else seems ok.  I’ve only used the motor once and I’m sure there will be more things to deal with.). I have an EZKontrol controller. Just wondering if you have all cables connected. From memory it cruise, brake and alarm that aren’t connected.
