Author Topic: Coolant for 10 kW BLDC motor  (Read 42161 times)
Offline Pontus
    • Grinde 19
« on: September 22, 2022, 12:04:04 PM »
In winter temperature drops below 0 C where I live. Therefore I plan on use some kind of antifreeze for the coolant loop.
I would like NOT to use the antifreeze of choice for internal combustion engines - glycol, which is which tend to be rather sticky.
I'm thinking of using ethanol/alcohol instead. A 50/50 mix would be good down to -28 C.
Is there any considerations regarding aluminium and alcohol?
Follow along my electric conversion of a 4 ton Danish sail boat. Grinde 19
