Author Topic: 50A fuse with my Magic Pie 3 kit  (Read 37138 times)
Offline ElectricStreet
« on: August 08, 2022, 11:41:31 PM »
My 50 Amp fuse box.  Is this aa optional item or do they all do this?
Re: 50A fuse with my Magic Pie 3 kit
« Reply #1 on: August 09, 2022, 04:30:31 AM »
I found one.  I guess it's a breaker for the motor.  Limits Amps.  OK.  Do I need it?  Should I install it?  Pros vs. cons
« Reply #2 on: August 16, 2022, 11:38:04 AM »
If your battery has a BMS, you shouldn't need an additional circuit breaker or an external fuse on the main battery connection, as this would introduce more areas that could be prone to possible failure.
If you keep things nice and simple, you'll reduce the possibility of problems arising at a later date as there are fewer things to go wrong.  ;)
