Author Topic: Boat Throttle for 48V Golden Motor  (Read 50376 times)
Offline Bilgola
« on: January 19, 2022, 06:53:48 AM »
Just took delivery of 10kw motor and controller, can anyone advise best type of throttle controller for a boat installation  ?
Re: Boat Throttle for 48V Golden Motor
« Reply #1 on: January 20, 2022, 02:50:55 PM »
The only boat throttle I could find on the GM website was this one:
The controller should work with any 10k Ohm potentiometer type throttle or 5V Hall sensor type, but you would need to decide whether you require a single direction throttle and a separate reverse switch, or use a bi-directional throttle like the one shown above (push forward to go Forward, pull back for Reverse, and Neutral in the mid position).
The throttle shown above also appears to have a three position switch to select different power modes (Economy, Normal and Sport).
Offline Major Clanger
« Reply #2 on: January 24, 2022, 06:11:27 PM »
I just bought a more reasonably priced unit from a company in Lithuania called miramax.  Their service was good but obviously depends where you are located.
