Author Topic: "Dishing" Front Hub motor to center Rim/tire  (Read 41905 times)
Offline diverdon
« on: December 11, 2021, 09:06:59 PM »
   Hello All ..I saw something about "wheel dishing the other day .. The Magic Pie Vector 5 100 watts front hub has the tire/rim offset between the forks ..They do this to allow for disc brakes ..I don't have disc brakes ..
    Just wondering if the offset could be "dished" out ???
     Love the Magic Pie ..this is my third one ..I ride most every day now ..
Re: "Dishing" Front Hub motor to center Rim/tire
« Reply #1 on: December 11, 2021, 11:10:46 PM »
Hi Don,
It's the hub that needs to be slightly offset to the right to allow additional room for the brake disc on the left - not the rim.
If you have a cast 16" or 18" front wheel and suspension forks, there is not much that can be done to reduce the offset. I may be possible the tweak non-suspension steel forks slightly to reduce the offset.
However, the cast 20" front wheel should be correctly centred if GM have followed my suggestions correctly.
A spoked rim can be offset slightly to the left in relation to the motor, so it can still be correctly centred between the forks provided that the spokes have been correctly adjusted and tensioned.
If you have a spoked front wheel and your rim is not centred between the forks, it should be possible to adjust it (after making sure that the wheel has been installed perfectly upright in the fork dropouts) by adjusting the spokes to bring it into the correct position.
I would start at the valve and then slacken in turn the nipples of all 18 spokes on the side of the rim that is closest to the fork one complete turn until I reached the valve again.
I would then tighten each nipple on the 18 opposite side spokes one complete turn until I reached the valve for the second time and then check the offset.
You may have to repeat this process several times (using smaller or larger adjustments as necessary) until the rim is properly centred within the forks.
Hopefully you can understand what I'm trying to explain.
Offline diverdon
« Reply #2 on: December 12, 2021, 08:56:51 PM »
   Hi Alan ..thanks for the help ....Again ..your the best .. I do understand what your saying ..I have had some bad experiences with spokes ..not with this wheel ..their all tight and have never loosened wheel has stayed straight ..except for off center ..
   I was hoping this had a fix that many have used ..maybe an easy one .. I don't even know if it would make a difference ..This Bike has never had any other front wheel ..Seems OK ..I cannot ride hands free ..too squirrely  ..maybe that's just the bike .. I will try to post a pic of the tire off center with the fork ..
       Thanks sooo much for your help ..
