Author Topic: What is Regenerative Braking and how is it used?  (Read 27510 times)
Offline Ron Burgundy
« on: July 02, 2020, 01:52:05 PM »
I just installed the Smart Pie rear wheel motor kit and I am trying to understand how regenerative braking works and how to use it. I assume that it will feel like braking is occurring without the need for mechanical brake deployment?  ???
Re: What is Regenerative Braking and how is it used?
« Reply #1 on: July 02, 2020, 08:18:55 PM »
The regenerative braking force on a Smart Pie is not as strong as mechanical brakes but it really helps to reduce wear on the mechanical brakes under light braking.
Check out this thread for more details.
« Reply #2 on: July 02, 2020, 08:58:13 PM »
Excellent thank you!
I assume that I can safely turn the regen setting in my software to MAX.
« Reply #3 on: July 02, 2020, 10:06:02 PM »
Max regen should be fine if you have larger wheels, but it might be too much if it's a 12" wheel on the rear of a scooter.  ;)
I suggest that you try it and see what it's like, you can always reduce it if it is too strong.
« Reply #4 on: July 02, 2020, 10:45:08 PM »
Thanks very much for the advice. I was worried about it causing an issue within the charging side, not so much about the brake force.
