Author Topic: Lead acid goes down by 50% and LiFePo4 goes down 80%, does that mean?  (Read 73318 times)
Offline SherylinRM
Ok so I probably got it wrong but....
If lead acid batteries can only safely go down to 50% of capacity. But LiFePo4 can go down to 80% of capacity.
Does that mean for the same amperage I can get 30% more mileage on my mobility scooter?
Sounds Like I should be able to.
Anyone here with the big brains able to help me out?
Thanks guys.   :D
I read a book that has "Don't Panic" on the cover ;) LOL
If you only used 50% of a lead Acid battery, using 80% of a Lithium battery of the same capacity (Ah) should provide at least 60% more range (0.8/0.5x100=160%) but I suspect that you may well be using more than 50% of the Lead Acid battery's capacity.
A lithium battery of the same capacity would also weigh a lot less compared to the Lead acid battery.
Lithium batteries are a lot more efficient and have less voltage sag under higher discharge rates compared to Lead Acid batteries, therefore you should get even more mileage at the same current draw from a lithium battery compared to a Lead Acid battery of the same rated Ah capacity.
The slightly higher nominal voltage of the LiFePO4 battery (12.8V instead of 12V) combined with the reduced voltage sag results in more power for the same amount of current being drawn, therefore you will require less current to maintain the same speed, which should also extend the available range.
Quote from: relionbattery.com
Lead Acid Batteries Lose Capacity At High Discharge Rates
Peukert’s Law describes how lead acid battery capacity is affected by the rate at which the battery is discharged. As the discharge rate increases, the battery’s usable capacity decreases.
A typical battery’s capacity is measured by the current that is required to fully discharge in 20 hours. If your application’s discharge current exceeds the manufacturer’s 20-hour rate, Peukert’s Law explains why your battery capacity becomes significantly reduced.
However, this law does not hold true for lithium-ion batteries due to the technology’s high level of efficiency. Lithium-ion battery capacity remains satisfactory for years after installation, regardless of your discharge rate.
Lithium-Ion Batteries Have A Higher Usable Capacity
In many applications, lead acid batteries are sized to a 50 percent depth of discharge in order to extend battery life. This means you are taking up twice the amount of space and adding extra cost, neither of which are efficient options.
Rechargeable lithium-ion batteries are 99 percent efficient and offer a much higher usable capacity at the same Amp-Hour (AH) rating. Lithium-ion technology commonly provides 20-50 percent more usable capacity and operational time depending on the discharge current.
This allows you to substitute your lead acid battery with a much smaller, lower capacity lithium-ion battery to achieve similar results and run time. Additionally, lithium-ion battery life far exceeds the life span of lead acid batteries.
Basically, you will get more miles per Ah from a Lithium battery than you get from a Lead Acid battery. So if you changed from a 160Ah Lead Acid battery to a 320 Ah Lithium battery you would get a lot more than double the range if you used the full 100% capacity of both batteries.
« Last Edit: June 19, 2020, 11:28:29 AM by Bikemad »
Offline SherylinRM
Cool.
Exactly as I thought :)
And from your quote it even states that lead acid go down 50%. Where as for practical purposes a lifepo can go safely down to say 80%.
So if I replaced my 50Ah lead acid with 50Ah lifepo, then I would go further on the lifepo by a large amount.
Thanks a lot yet again Alan :)
You really are a fount of information.
I guess you have done this a couple of times eh? LOL
