Author Topic: Smart Pie problems  (Read 58177 times)
Offline Asybre
Re: Smart Pie problems
« Reply #15 on: April 27, 2018, 01:04:32 PM »
Checked all the connections, did them again in a proper way that I know for sure everything is fine. I have disabled the regen but the controller still does the brake thing so I am not sure whats doing it. I have to get the new throttle to get some improvements I guess.
I all else fails I will have to buy a new controller.
Offline Asybre
« Reply #16 on: May 03, 2018, 10:10:02 AM »
Hey guys!  :D
New throttle came yesterday, while I was trying to connect it I checked the wrong pinout and managed to burn the hall sensor.... today I switched it for the hall sensor of the old twist throttle and the motor was acting the same way... I checked the throttle voltage and it seams to be all ok, from .8 to 3.5V.
With all this I am assuming the controller is busted so the next step is to get a new one. If anyone has a suggestion for one that works from 48-60V and around 1000-1500w, please let me know!
 8)
Thanks for the support!
Offline Tommycat
« Reply #17 on: May 03, 2018, 01:17:36 PM »
Hey! Since your close to chucking your controller... :-\ did you try the firmware flash update? Couldn't hurt now... ;)
...Gary's video.
