Author Topic: Separate issue: Bluetooth App is not working  (Read 321906 times)
Offline Wilson_wu
« on: July 11, 2017, 05:18:11 AM »
It seems I'm not alone in that the Bluetooth app does not work. While I can see the speed and whatnot, I cannot modify and save any changes through the app. This is fine as I do not mind using my USB cable.
Anyone have links to the older versions of the app? The ones I scavenged for seem to be down.
However, I am worried though, will this Bluetooth App glitch affect my ability to use my pedelec and the ability to switch from 1 to 5 if I am having this issue?
« Last Edit: July 11, 2017, 08:37:02 AM by Wilson_wu »
Offline Papagino
    • Colloidal silver, your immune system's best friend...
Re: Separate issue: Bluetooth App is not working
« Reply #1 on: July 11, 2017, 07:08:46 PM »
I had the same problem...
Here is goldenmotor1.1.apk that should work with Magic Pie 5...
Let me know if it doesn't so I can send you the other versions...
Cheers
EDIT: Title changed to help locate attachment
« Last Edit: July 12, 2017, 10:50:35 AM by Bikemad »
Offline Wilson_wu
« Reply #2 on: July 11, 2017, 10:40:32 PM »
Thank you!!! I am going to try these when I get home later. Do you by any chance have versions 1.31 or 1.30?
EDIT: I tried version 1.1 it won't even open :(
Thanks!
« Last Edit: July 11, 2017, 10:43:20 PM by Wilson_wu »
Offline Wilson_wu
« Reply #3 on: July 12, 2017, 04:06:48 AM »
I realized why the Bluetooth app is crashing.
The app works fine when I am at home, but the app always crashes when I am in a public place where there are other bluetooth devices in the vicinity.
Perhaps the developer of this app (if there still is one) should make a note of this issue? It seems there's issues when my bluetooth scans and finds other devices near me.
« Reply #4 on: July 12, 2017, 10:07:51 AM »
Bluetooth Apk 1.13 attached
« Reply #5 on: July 12, 2017, 10:09:34 AM »
Bluetooth Apk 1.30 attached
« Reply #6 on: July 12, 2017, 10:10:40 AM »
Bluetooth Apk 1.31 attached
« Reply #7 on: July 12, 2017, 10:11:27 AM »
Bluetooth Apk 1.32 attached
Offline Wilson_wu
« Reply #8 on: July 12, 2017, 10:14:55 PM »
None of the APK's worked on my newer version of Android. I could load the app, but not save any parameter changes to the controller.
However, when I connected the 1.30 APK to my older Android 4.4 phone, it works and I can save the settings to the controller via Bluetooth!!! I love you Alan! Thanks man! :) Now I have to take my phone to the mall and see if it crashes. That's another story. :)
« Last Edit: July 12, 2017, 10:16:53 PM by Wilson_wu »
Offline Wilson_wu
« Reply #9 on: July 12, 2017, 11:11:17 PM »
Spoke too soon.
All 5 versions crash when I'm in a public place. :(
« Reply #10 on: July 13, 2017, 09:29:12 AM »
Could someone be using an illegal cell phone jammer that is interfering with your Bluetooth signal and causing the App to crash?   :-\
Try another public place and see if the problem reoccurs.  ;)
« Reply #11 on: September 21, 2017, 08:40:12 PM »
Bluetooth Apk 1.6 attached
Offline Papu
« Reply #12 on: December 12, 2017, 05:47:56 PM »
    please someone can suggest a cell (brand and model) that certainly works with this app, I've already tried several but nothing to do....
tnx in advance
           carlo
« Reply #13 on: December 14, 2017, 10:00:16 PM »
Hi Carlo,
The two phones I use successfully are both Samsung Galaxy Core Primes, the older one (SM-G3608) is running Android 4.4.4 and the newer one (SM-G361F) is running Android 5.1.1.
Check out this thread for further details.
« Reply #14 on: December 16, 2017, 02:22:19 AM »
I successfully use a:
Samsung Galaxy 3 with Android 4.4
https://www.youtube.com/watch?v=Z2EM2DLkr-o&t=534s
and a Motorola MotoE2(4G-LTE) with android 6.0
https://www.youtube.com/watch?v=l_hnwBeIra0&t=25s
