Author Topic: Battery - Cut Through Charging Lead  (Read 23904 times)
Offline Bedmountain
« on: May 13, 2016, 08:30:39 PM »
Hi All
I just managed to cut through the charging lead on my new Lithium battery.
Big spark and bang...
What kind of damage have I just done to the battery/BMS?
This is a triangle shaped battery bought direct from china wrapped in blue plastic.
I think I can see some slight swelling now at one end that I'm pretty sure wasn't there before :(
Re: Battery - Cut Through Charging Lead
« Reply #1 on: May 13, 2016, 09:57:12 PM »
Hi Ben,
Most BMS units will have some form of short circuit protection built in, but it is usually on the power output lead and may not protect against a short on the charger supply.
Some BMS have a separate connection for the charging current whereas others share the same connection as the power output.
Even with short circuit protection, it still takes a small amount of time (and a large amount of current) to activate the current overload protection function, which can still cause a nice big fat spark accompanied by a very loud bang.
As yours is a triangle battery, it is most likely constructed from the more common LiMn 18650 cylindrical cells which are usually equipped with safety pressure release valves at the positive end:
Therefore the cells won't swell up like the soft pouch Lipo and LiFePO4 prismatic cells can:
If the wires that you "managed to cut though" did not get hot enough to melt their insulation, then I would say that the cells are probably fine.
I would first give the battery a good sniff where the wires exit the covering to determine if there is any sign of a horrible burnt smell inside that might indicate whether any components have been blown up on the BMS etc.
If it smells OK, I would carefully repair the damaged wiring and then check that the battery still charges correctly (preferably with it removed from the bike and placed outdoors in a safe place, and keeping a watchful eye on it just in case).  ::)
If it charges correctly and still provides the same amount of power for the motor as it did before, then it may have survived the ordeal without any permanent damage.
Unfortunately, without dismantling the battery to gain access to the BMS and balance lead connections etc., you won't be able to inspect the BMS unit for any signs of physical damage, or check the voltage of the individual cell groups to check that the BMS is still balancing all the cells correctly.
« Last Edit: July 04, 2017, 11:21:38 PM by Bikemad »
Offline Bedmountain
« Reply #2 on: May 15, 2016, 06:48:07 PM »
Thanks Alan
Yes the battery is made up of LiMn 18650's.
I can't smell any burning and the wires were slightly blackened but no insulation was melted.
The bottom of the pack does look slightly swollen but as you say the cells don't swell like LiPo so it must have always been like that...
Fixed the damage and charged it up today and my cycle analyst shows it at 54.6v so reckon I may have got away with it this time.
Thanks for your help as always.
