Author Topic: Using a capacitor to limit current from LIPO batt  (Read 28898 times)
Offline alfio
« on: March 12, 2009, 06:19:00 PM »
Hi ALL
I purchase the lipo batt 10ah 36v from Golden and I´m sad whith the cutoff imposed by the BMS when the current goes to 30 A (in brisk acellerations or hills). This force me to stop, turnoff the key, turn on again and restart the ride. My motor is 750W36V
You think that a capacitor solves it?? How it works? How to do it?
Thank you
Offline alfio
Re: Using a capacitor to limit current from LIPO batt
« Reply #1 on: March 19, 2009, 01:00:21 PM »
Thank´s for response
I´m worried about weight
What size and chemistry you think?
« Reply #2 on: April 06, 2009, 01:36:18 AM »
I think you're missing something important here.
750W / 36V = 20A
If you're running 30A, you're pulling more than
1000 Watts in your 750W motor.
That means you're overheating the motor, and
that's probably not a good thing.
You probably want to think about the 1000W motor
if you're planning on regularly pulling 30A.
Offline alfio
« Reply #3 on: April 08, 2009, 05:50:14 PM »
Thanks for response
After a couple weeks I´m learning to avoid the cutoffs.
I intend to put another pack (booster pack).
If I use a diode to separate the packs may I use a 36V,  2000maH NimH (30 AA)???
