Author Topic: Mp4 adding RC hobby watt meter.  (Read 23383 times)
Offline Mgizen
« on: January 04, 2016, 03:29:54 AM »
Are Deans connector rated for enough amps if used with Mp4 at 48 set to default settingsettings?
Re: Mp4 adding RC hobby watt meter.
« Reply #1 on: January 04, 2016, 12:10:44 PM »
I use the HobbyKing version of the Deans "T" style connectors and have found them to be more than capable of carrying the 30~35 amps that the MP4 draws:
On my modified MPII, my wattmeter regularly records a maximum current ~50 Amps and the connectors have been in use for over 5 years so far.
This is the maximum measured current that I have inflicted upon them, which they handled without a problem :
Although I have discovered that they are not able to withstand an accidental direct short while trying to connect to an unprotected high current LiPo pack:
My 30c 10Ah LiPo pack was capable of delivering 200 Amps continually and 300 Amps for short bursts, so I was not surprised to discover that the connector was unable to survive a direct short circuit with such a high current.
« Last Edit: July 04, 2017, 07:52:55 PM by Bikemad »
Offline Mgizen
« Reply #2 on: January 04, 2016, 06:22:18 PM »
Thanks for info Alan. :)
Offline NR
« Reply #3 on: January 04, 2016, 09:51:34 PM »
I have used deans in rc and find them very robust for everyday use, the doesnt melt before 130-140 amps, which most e-bikes seldom exceeds  ;D
