Author Topic: Desperately need the FRONT Magic Pie 5/4 Measurements.  (Read 30806 times)
Offline AdamB
« on: September 27, 2015, 09:13:25 PM »
Stupid forum keeps deleting my posts randomly when it isn't happy that I'm not paying it enough attention... I guess I'll have to try again... Stupids message board!!!
I'm looking for the FRONT 26" Magic Pie 5 (MP5), failing that FRONT 26" Magic Pie 4 (MP4) (been told they are dimensionally the same) dimensions, measurements, schematic, anything!
I've been able to find just about everything except the front MP5's/MP4's measurements! It's like the line "water, water whatever but nothing to drink"...
I'm trying to get the info I need to add to the spoke calculator but there's nothing out there as far as I know. It's really stupid that GM China doesn't show this info for the MP5/MP4 & just leaves the end users to have to try to accurately measure everything! I'm not able to measure this stuff accurately but I spent forever trying to figure it out & I'm not getting anywhere! It's not like I'm asking for engineering plans or state secrets... I just want accurate measurements so I can easily use my motors... Why is that so difficult?
I know I'm not alone, lots of people have replaced spokes, relaced & re/built the MP5/MP4; so they had to have these measurements... For mercy's sake, please post them here indicating front/rear, size, etc. That way everyone does not have to waste time trying to measure the things!
I thought I saw someone post the MP4's measurements but I can't find it anywhere. I also know Alan said the spoke calculator he recommended had the MPs info but it only has the MP3!
I know I'm not alone feeling frustrated trying to accurately measures or find this info! I know others have to have this info, even if it's just the hub but not the wheel, I'll take anything, please!
I'll do my share because I've found other motors schematic & I'll post them here but please someone post the front Magic Pie 5/4!
Meanwhile, hey GM China! Get your act together & publish the front MP5 & MP4's schematics! It's not secret but not doing it will cost you customers when people see that they can't get the simplest yet essential info from you about your products!
I'll stop here but there's more to transcribe & organize still...
Adam
Rear MP1 schematics- http://www.goldenmotor.com/hubmotors/Magic%20Pie%20Sizes%20Model.pdf
Rear MP1 3D Schematic (requires viewer)- http://www.goldenmotor.com/hubmotors/MagicPie-3D.EASM
Front Smart Pie Schematic- http://www.goldenmotor.com/hubmotors/SmartPie%20Front%20Hub%20Drawing.pdf
Rear Smart Pie Schematic- http://www.goldenmotor.com/hubmotors/SmartPie%20Rear%20Hub%20Drawing.pdf
Smart Pie & Magic Pie III Wiring Layout- http://www.goldenmotor.com/e-Bike-DIY/MP3%20SmartPie%20Wiring%20Layout.jpg
36V cast MP Wheel Performance Data- http://www.goldenmotor.com/magicpie/16in%20MagicPie%20Performance%20Data.pdf
24V MP Performance Data- http://www.goldenmotor.com/magicpie/MP-performance%20data%2024V.pdf
24V MP Performance Curve- http://www.goldenmotor.com/magicpie/MP-performance%20curve%2024V.pdf
36V MP Performance Data- http://www.goldenmotor.com/magicpie/MP-performance%20data%2036V.pdf
36V MP Performance Curve- http://www.goldenmotor.com/magicpie/MP-performance%20curve%2036V.pdf
48V MP Performance Data- http://www.goldenmotor.com/magicpie/MP-performance%20data%2048V.pdf
48V MP Performance Curve- http://www.goldenmotor.com/magicpie/MP-performance%20curve%2048V.pdf
Front Mini Schematic- http://www.goldenmotor.com/hubmotors/MiniHubMotor(Front).pdf
Front Mini 3D Schematic (requires viewer)- http://www.goldenmotor.com/hubmotors/Mini-Front-Motor-Drawing.EASM
Front Mini Motor Performance Curve- http://www.goldenmotor.com/hubmotors/Mini%20Rear%2036V250W%20Performance.pdf
Rear Mini Schematic- http://www.goldenmotor.com/hubmotors/MiniHubMotor(Rear).pdf
Rear Mini 3D Schematic- http://www.goldenmotor.com/hubmotors/Mini-Rear-Motor-Drawing.EASM
Rear Mini Motor Performance Curve-  http://www.goldenmotor.com/hubmotors/Mini%20Rear%2036V250W%20Performance.pdf
36V 500w Rear Hub Motor Schematic- http://www.goldenmotor.com/hubmotors/hubmotor-REAR_WHEEL.pdf
36V 500w Rear Hub Motor 3D Schematic (requires Viewer)- http://www.goldenmotor.com/hubmotors/HBS-36R.EASM
36V 500w Rear Performance Curve- http://www.goldenmotor.com/hubmotors/HBS-36V500W%20Performance.pdf
36V 500w Front Hub Motor Schematic- http://www.goldenmotor.com/hubmotors/hubmotor-FRONT_WHEEL.pdf
36V 500w Front Hub Motor 3D Schematic (requires viewer)- http://www.goldenmotor.com/hubmotors/HBS-36F.EASM
36V 500w Front Hub Motor Performance Curve- http://www.goldenmotor.com/hubmotors/HBS-36V500W%20Performance.pdf
MW-12sp Schematic- http://www.goldenmotor.com/hubmotors/12inchSmartWheel.jpg
48v MW-12sp Performance Curve- http://www.goldenmotor.com/hubmotors/SP3-48v-Performance.pdf
36v MW-12sp Performance Curve- http://www.goldenmotor.com/hubmotors/SP3-36v-Performance.pdf
24v MW-12sp Performance Curve- http://www.goldenmotor.com/hubmotors/SP3-24v-Performance.pdf
MW-16B Schematic- http://www.goldenmotor.com/hubmotors/MW16B%20Drawing.pdf
MW-16B 3D Schematic- http://www.goldenmotor.com/hubmotors/MW16B.EASM
MW-16B Performance Curve- http://www.goldenmotor.com/hubmotors/hubmotor-36V_450W.pdf
HUB24E Schematic- http://www.goldenmotor.com/hubmotors/HUB-24M.jpg
HUB24E Performance Curve- http://www.goldenmotor.com/hubmotors/24V%20180W%20Black.pdf
See for more- GM.com- Hub Motors Page- http://www.goldenmotor.com/index.htm
« Last Edit: September 28, 2015, 02:02:28 PM by Bikemad »
Re: Desperately need the FRONT Magic Pie 5/4 Measurements.
« Reply #1 on: September 28, 2015, 01:58:42 PM »
Here are two drawings with some dimensions for the Magic Pie 3, 4 & 5 front and rear motors:
The drawings don't show the dropout measurements including the thickness of the two axle washers that fit inside the dropouts:
But the motors usually fit most 100mm front dropouts or 135mm rear dropouts.
Regarding the spoke calculator, the physical dimensions of the MPII, MPIII, MP4 and MP5 are pretty much the same with just a slight difference in the flange spacing which would not affect the required spoke length.
The original MkI Magic Pie is the only one that is different as it does not have the benefit of the paired holes:
This picture clearly shows the difference between the two spoke lengths used for the 26" GM rims fitted to Magic Pies.
The longer spoke is for the MkI version and the shorter spoke fits MPII, MPIII, MP4 and MP5.
The original Pie had crossed spokes as indicated by the dotted lines in the above diagram.
The MP4 hub  is the same as the MPIII apart from the vector controller and a slightly different stator winding configuration.
The MP5 hub is identical to the MP4 but has a more recent controller that supports Bluetooth connectivity.
To use Justin's Spoke Calculator you simply select the Magic Pie III hub from the drop down list and make sure you select a cross pattern of "0" or the angle between the spoke and the rim will be too large to allow the nipples to seat correctly in the rim.
« Last Edit: August 13, 2024, 10:18:31 AM by Bikemad »
