Author Topic: Smart Pie 4 connectors  (Read 22137 times)
Offline Yonkers
« on: August 02, 2015, 04:49:14 PM »
what type of wiring connectors does the Smart Pie 4 come with? the connectors that go the battery  are the important ones, ie dean?
Re: Smart Pie 4 connectors
« Reply #1 on: August 02, 2015, 10:36:32 PM »
If you purchase a hubmotor kit and a battery at the same time, the power cable from the motor usually comes with the correct connector for the battery.
However, if you purchase just the hubmotor kit without a battery, the ends of the power cable are simply left bare and unterminated ready for you to fit connectors of your own choice to suit whatever battery connections you are using.
« Last Edit: July 02, 2017, 04:15:14 PM by Bikemad »
