Author Topic: Using single throttle and brake on two motors  (Read 25950 times)
Offline Yeekevin11
« on: July 28, 2015, 01:17:28 PM »
I am attempting to wire a single throttle and a single brake to two Magic Pie 4's. Is there a schematic and/or pin-out diagram of the throttle and brake cables that I can use in order to create the parallel lines?
Any advice is appreciated. Thanks.
Offline Yeekevin11
Re: Using single throttle and brake on two motors
« Reply #1 on: July 28, 2015, 01:27:57 PM »
I was able to find this for the MP3. I would like something similar to MP4. Thanks
http://www.goldenmotor.ca/FAQ/questions.php?questionid=99
« Reply #2 on: July 28, 2015, 05:02:11 PM »
I think this is what you are looking for:
You can link the Throttle Signal, Cruise Signal, Brake Signal, Battery+ and Battery- (Ground) but do not connect the two +5V wires together as this has been found to cause problems.
« Last Edit: July 04, 2017, 11:20:38 PM by Bikemad »
Offline Yeekevin11
« Reply #3 on: July 30, 2015, 06:00:10 PM »
Thanks, Alan. This looks great. Do you happen to know which color wire correspond to which pin? Thanks
« Reply #4 on: July 30, 2015, 08:35:52 PM »
I have no idea what the colour of the wires inside the harnesses are so you would have to do a continuity check using a sharp pin in each of the wires to identify which wire goes to which pin.
There might be some further information here but I don't know if it contains what you are looking for.
