Author Topic: Using external controller on Magic Pie 4  (Read 25039 times)
Offline Yeekevin11
« on: June 11, 2015, 04:38:11 PM »
I'm trying to using a higher voltage battery (~72 V) with the Magic Pie 4 in order to increase the max speed which means I'll need to use an external controller that can handle that much voltage. Specifically, I'm interested in this controller:
http://Kellycontroller.com/keb72300x24v-72v150a30kw-bike-brushless-controller-p-273.html
What's the best strategy for wiring up the Magic Pie motor to this controller?
Re: Using external controller on Magic Pie 4
« Reply #1 on: June 11, 2015, 06:26:24 PM »
That controller would require some pretty hefty gauge phase wires combined with a high output battery to handle up to 150A, which is a lot more than the motor will handle for any length of time without overheating.
You would also need some very secure torque arms to prevent the axle from spinning with the extremely high torque that these motors can produce.
My modified 26" Magic Pie drew 97.75 Amps on a 51.8V 5Ah LiPo pack would simply flip the bike over backwards from a standstill:
GM had an external controller modification for the MPIII, but I don't know if this was just a one off for their own test purposes or whether they were actually mass produced for customers:
It should be possible to convert the MP4 in a similar fashion, but you will need to make a cover plate to fit in place of the existing controller. I would suggest making a paper template and transferring the shape and hole positions onto a piece of 3mm Aluminium.
As the windings and magnets are all pretty much the same (Although I think that the MP4 has a slightly different winding pattern) a cheaper option would have been to use the external MPII or even convert an MPIII rather than modify the more expensive MP4.
« Last Edit: July 02, 2017, 11:27:42 PM by Bikemad »
Offline Ron
« Reply #2 on: June 12, 2015, 08:34:28 AM »
The 150A is on the phase current and is only allowed in burst mode for 10seconds.  Maximum continuous phase current is 60A.  This controller has twice the power rating of the stock MP4 controller, 3000 watts.
Do keep the forum posted on your progress and good luck!
Ron
