Author Topic: new throttle help  (Read 28435 times)
Offline tartosuc
new throttle help
« on: March 03, 2009, 04:42:00 PM »
HI,
I got a 36v front kit without regen.
I have the older style controller and seperate throttle and power meter.
on the  controler side, the trottle connector is male(red green and black wires) and on the trrottle side is female(red, blue and black wires)
I bought the newer 36v throttle kit wit intergrated power meter..
I wanted to plug it in but realized that I end up with 2 males connectors! the throttle side is male also! (red blue and white wires)
I want to make sure that I will connect things right, what should I connect to what?
what am I supposed to measure on the diferent wires.
any help would be welcome.
thanks
« Last Edit: March 03, 2009, 05:40:27 PM by tartosuc »
Re: new throttle help
« Reply #1 on: March 04, 2009, 11:43:56 PM »
I got a bag of female pins and connectors with my kit to
deal with that.
You can ask GM to send you connectors, but if I were in your
shoes I would just re-use the connectors from your old meter
and throttle.
There was a strangeness on the throttle wires, but there
are only two ways to hook it up once you figure out the black one.
Offline TOM
« Reply #2 on: March 05, 2009, 01:28:48 AM »
Some spare connectors are in your package.
You could use these connectors to replace the one from the throttle so that you can connect to your controller.
It doesn't matter about what kind of connector and which place your three wires
IMPORTANT:
Throttle   ---------  controller
red wire     -----      red wire
blue wire    -----      black wire
white wire  -----      green wire
Offline tartosuc
« Reply #3 on: March 05, 2009, 01:18:37 PM »
IMPORTANT:
HI,
i never got any spare connectors...
I've cut the wires and used some terminal block connectors to make connection.
I mostly needed the wires color codes to make sure I connect things the right way.
thanks for the details, I will try that tonite!
« Last Edit: March 05, 2009, 01:21:37 PM by tartosuc »
Offline b-twinelec
Connector Type
« Reply #4 on: May 12, 2009, 09:16:06 PM »
Hello,
I want to order more of those multiplug connectors but I am struggling to find supplier on the internet and as well name and reference for those.
Would somebody have their reference or a website where I could source them from?
jb
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« Reply #5 on: May 13, 2009, 02:43:45 AM »
Hello,
We sell the complete wiring sets now, if you'd like to pre order, please drop me a mail.
