Author Topic: Black magic front motor broken after less than a mile  (Read 23797 times)
Offline Gadadhoon
« on: April 15, 2015, 08:34:29 PM »
I built a bike with the GM black magic front motor and 36v 12 Ah battery. I took it out for a test run around the block and it was great. This afternoon I tried to ride it to work after lunch. The battery indicator says it's full, but the motor barely even provides assist and won't start unless it's already spinning well. It vibrates excessively. I noticed that the rubber rings on either side of the motor around the axle are sideways and twisted, they were flat before. I'm a little pissed about this, help me out guys, what do I do?
Re: Black magic front motor broken after less than a mile
« Reply #1 on: April 16, 2015, 11:16:07 AM »
It sounds as if it might be a hall sensor or wiring problem to me.
Presumably the wheel still turns smoothly without power?
Check that all the wires are correctly inserted into their connectors. If that doesn't help I would suggest unplugging the hall sensor connector from the controller and see if the motor then runs smoothly, but you will still need to have the wheel spinning before the throttle will work.
If it runs smoothly with the hall sensor plug disconnected then I would say it could be a failed hall sensor or broken wire.
If it is still vibrating badly in sensorless mode it is likely to be a poor connection on one of the three phase wires, a controller fault or possibly a fault with the motor windings.
Please let us know what you find.
