Author Topic: MP4 disc brake caliper rubbing on it  (Read 25942 times)
Offline Ag3n7
« on: September 10, 2014, 05:50:45 PM »
Purchased the MP4 and really happy with it. Silent, powerful, fantastic. However, I noticed that my disc brake caliper is rubbing against the motor shell. It obviously effects the efficiency and wanted to know if anyone has the same issue? I tried shifting the calipers but unfortunately it cannot be adjusted. I can grind down the plastic that is rubbing but I am sure a few more rides to and from work will grind it down for me but again, just wondering if anyone else is having this same issue?
Offline Eriknoort
Re: MP4 disc brake caliper rubbing on it
« Reply #1 on: September 10, 2014, 08:28:48 PM »
I had the same problem on my mpIII. I solved it by using a bigger disk (180mm)
Offline Pwd
« Reply #2 on: September 11, 2014, 12:05:35 AM »
Unless you can add spacers to the disk and the hub-motor, I think grinding it down is the only option.
Offline Ag3n7
« Reply #3 on: September 12, 2014, 02:01:06 AM »
Thanks for the suggestions.
Eriknoort, when you got your bigger disc rotor, I am assuming that you kept everything else the same and installed the mount adapter for the calipers to reach??
Offline Bedmountain
« Reply #4 on: September 14, 2014, 10:50:32 PM »
Hi - I had the same problem with an MP3 build and I ended up grounding down the caliper by about 7mm - did it manually with a file and took about half an hour...
