Author Topic: Need help for USB - Connection on a HPC300H Controller  (Read 23745 times)
Offline Flytronic
« on: July 29, 2014, 06:32:37 AM »
Dear all @ GM,
I have a proto running containes a  HPC300H on a HPM5000B Motor.
To bring things forward I need to get monitoring data out of the Controller.
So I started to make my connetion on a self made wirering to the USB Hub on my labtop PC.
In the data sheet recenty downloaded again from the GM-website the pins for Programmer-Connection a pronounced as TXD and RXD. But this is not a part of any USB specification.
Can you please clarify the meaning for Pin 14 and 15 ? This should be a D+ and a D- Data Line to connect to a USB Hub direcly. Are these data lines for the internal USB Hub  ?
Anyway:
I not get any driver install when connect to these lines on using the MISVC-11-12-26.exe software for example. If someone had this up and running please let me know,
Thanks for your help
joerg
