Author Topic: MP3 brake function  (Read 23478 times)
Offline Just
MP3 brake function
« on: July 11, 2014, 09:42:18 AM »
Hi All,
Is there a way to disable the brake function in the MP3 Hub Motor? Could it be done by programming the Controller? Should I buy the program cable separately or it comes with the motor hub?
Thank you!
Re: MP III brake function
« Reply #1 on: July 11, 2014, 04:39:38 PM »
Just disconnect the signal cable to the brake handle.
Offline Just
« Reply #2 on: July 11, 2014, 04:49:56 PM »
I see, thanks Dennis! Should I not need to connect it to GND? Just left it floating?
How many wires comes from/to the MP3 with Internal Motor?
Is there a connection schema how to connect all these wires?
« Last Edit: July 11, 2014, 04:52:32 PM by Just »
« Reply #3 on: July 11, 2014, 08:02:19 PM »
My GM brake handles had connectors on the signal cables.  I just unplugged them from the "Y" connector that was part of my MP3.
Oh, I taped the open connector ends to keep water out..
« Reply #4 on: July 11, 2014, 09:56:21 PM »
How many wires comes from/to the MP III with Internal Motor?
The more recent wiring harness is slightly different to the diagram shown here:
It has a slightly different multiconnector block like this:
instead of this:
If you are not planning on using the brake switches you might want to consider using the horn switch to operate regen as it would also work as a safety switch to cut the power when the motor runs on its own due to water finding its way inside the throttle unit.  ;)
« Last Edit: December 18, 2020, 02:24:46 PM by Bikemad »
