Author Topic: MPIII Throttle control  (Read 20995 times)
Offline Ijmccubbin
« on: April 26, 2014, 08:34:07 AM »
Hi all,
I am using two MPIII front motors to drive a modified "Segway".  Thumb throttles are fine for now but I was going intending to add some more personalized control features using my own signals.
My main concern is throttle control.  If I inject a signal up from the throttle pin to ground, I get no output from the motor.  When I hook the thumb throttles back up, everything works fine.
Does anyone know the signal range or has anyone tried to control the mpIIIs throttle/brake/reverse using something other than twist/thumb throttles?
Any help would be greatly appreciated
Re: MPIII Throttle control
« Reply #1 on: April 27, 2014, 11:25:38 PM »
The throttle control is achieved by using a variable signal voltage of between 0.8V and 4.5V.
(Motor starts at ~1.25V and Maximum power is reached at ~3.25V)
The GM throttle uses a hall sensor to vary the voltage according to the actual throttle position, but a 10k potentiometer (variable resistor) should also provide variable throttle control.
The Brake, Cruise and Reverse functions simply use a switch to ground out the respective signal wire to operate the required function.
« Reply #2 on: April 28, 2014, 12:48:09 AM »
Ensure you have the polarity right.  neg to ground, pos (signal) to throttle pin.
Offline Ijmccubbin
« Reply #3 on: May 20, 2014, 09:28:15 PM »
Thanks gentlemen,  I will be attempting to perform the testing tomorrow.
