Author Topic: MPIII programming no connect  (Read 23480 times)
Offline Bwizz
« on: November 16, 2013, 11:36:59 AM »
Finally got my mp3 working, But having trouble getting the pie  to connect top the software. I don't get any beeps or for that matter any noise when connected. Not obvious but I have tried connecing with the pie turned on at the battery and of, but still no connect. noticed the reverse needs to be unselected. but stil no go . I need to turn down the pedal assist as it is to violent. also need to enable regen brake . any ideas appreciated
Offline Rodmiami
Re: MPIII programming no connect
« Reply #1 on: November 16, 2013, 02:34:27 PM »
Bwizz , The only thing that should be connected to the motor is the usb cable . Disconnect the battery feed to the motor at the connector nearest the motor . No battery is needed for programing . Rodmiami
Offline Bwizz
« Reply #2 on: November 16, 2013, 04:40:12 PM »
Would the on of switch not serve the same purpose, I'll try though and report back ta
Offline Bwizz
« Reply #3 on: November 16, 2013, 06:58:03 PM »
Tried with the battery lead disconnected, still will not connect, also uninstalled software and re installed still no beeps or life
Offline Sam.Vanratt
« Reply #4 on: November 17, 2013, 03:14:29 PM »
Hi Bwizz,
first: you have the normal USB MP3cable, didn't you?
second: What OS do you have?
third: how do you start it (elevated rights?)
fourth: what does your device manager show under USB or ports when you connect the cable (with or without the MP3)?
fifth: what software (version) do you have
CHeers
Sam
Offline Bwizz
« Reply #5 on: November 17, 2013, 04:56:12 PM »
Hi Sam , In order laptop sees normal usb /mp3 as human interface device. not sure on how do I start it question
I am using xp sp3
Offline Wombat
« Reply #6 on: November 17, 2013, 11:22:03 PM »
G'Day.
If I could butt in...
I had old S/W with "282" or "288" showing in top right corner. It worked OK run "as administrator" on Win 8 and worked normally on Win XP sp2. Beeps were heard as expected.
Yesterday I found another link was to a later version (executable time stamped about May '13). It works OK EXCEPT the beeps NO longer occur.
So so long as the red notifications show at the foot of the display window all should be ok. If not summinks really wrong.
PS also ALWAYS "DISCONNECT" before closing program!!!
Anyhoo...
Annoyingly the S/W saves whatever you change on the interface (EVEN if not saved to controller) to a file "Data.mxf". If the file doesn't exist it creates it at start up and again at program exit.
So, I discovered that the only way one could be sure the motor was being updated was to laboriously delete that file (folder open behind program) when ever it appeared in the program folder thus ensuring that what I "GET" from the controller was indeed just that (else the file just loads exactly the same thing as last selected all the time). ie whenever I start the program (no file) the options are blank until I "GET" the controller setup; if it then appears as expected then it has updated..
Hope that helps debugging a bit. Regards, Ron
Offline Bwizz
« Reply #7 on: November 18, 2013, 09:48:35 AM »
Early days of experimenting yet ,but  I think the programming is working despite not getting any now connected or beeps?
Offline Bwizz
« Reply #8 on: November 29, 2013, 03:22:16 PM »
The software is working but I don't get any ,Now connected or beeps. I have other issues though the pedalac function has stopped working,It is enabled in the software! Also the cruise control is very hit and miss any ideas appreciated
