Author Topic: Chain driven 48V+ CRF50  (Read 122451 times)
Offline Stomper
Re: Chain driven 48V+ CRF50
« Reply #15 on: November 17, 2013, 12:22:30 AM »
i made a drawing of a hollow frame.
could look a bit like this
Offline Stomper
« Reply #16 on: December 27, 2013, 12:11:20 AM »
Frame, 6061-T6 Aluminum ΒΌ" thick.
Battery pack Cylindrical cells, 3.2V 8AH 80Amp continuous current, 200Amp peak x40 (60v 16AH)
or this one
Prismatic cells with aluminum housing,
« Last Edit: December 27, 2013, 12:33:13 AM by Stomper »
Offline Stomper
« Reply #17 on: January 01, 2014, 07:00:18 AM »
Offline Stomper
« Reply #18 on: January 01, 2014, 07:13:56 AM »
Offline Eriknoort
« Reply #19 on: January 01, 2014, 09:35:57 PM »
It is looking good. Be aware that if you want tork you need lots of amps. I say 150A - 200A peak. Is your controller 3000W peak or continues. How many amps can the controller deliver to the motor?
Success with your project.
Erik
Offline Stomper
« Reply #20 on: January 02, 2014, 12:12:58 AM »
The battery I ordered is 80A cont and 150amp peak.
Controller is 100amp 4000w max but at 72v 4000W it should be around 55.5amp I think the 100A is when it works on 48v.
As long as I get the tork of a 50-70cc engine, I don't have to go far with it, I will use it to go to work 4KM and I can charge it there. with 20AH I wont go very far anyway :)
Maybe you know the answer to this question; I can open the hub motor from both side, if I open it, is anything fixed to this cover or it's only a cover?
« Last Edit: January 02, 2014, 12:24:03 AM by Stomper »
Offline Eriknoort
« Reply #21 on: January 02, 2014, 06:28:53 AM »
Normaly it are the bearings that holds the cover. You can heat it up a little with a hot air gun or something.
Offline Stomper
« Reply #22 on: January 02, 2014, 07:58:22 AM »
Thanks.
Offline Stomper
« Reply #23 on: January 06, 2014, 12:55:13 PM »
