Author Topic: 96V / 10KW  (Read 23208 times)
Offline Chris2K
96V / 10KW
« on: July 19, 2013, 03:03:48 PM »
I am about to buy the 10KW/96V motor, but I don't find any datasheet referring to this motor.
All I can find is 48/72/120 V datasheets. I'm intersted in RPM with 96V and the KV-coefficient or the Polepairs ?
Thanks for any help
Chris
Offline Chris2K
Re: 96V / 10KW
« Reply #1 on: August 27, 2013, 11:43:25 AM »
hmm, no answer... So what do I need to adjust running this motor on HPC 300 regarding the Motor Pole pairs ?
At the moment is is 4 but I think this is wrong. The motor is running but I think not that good as it should be.
I hope somebody can helb me with the controller-settings.
Re: 96V / 10KW
« Reply #2 on: August 27, 2013, 05:37:21 PM »
I think this is the data on the 96V motor:
http://www.goldenmotor.com/eCar/HPM96-5000Curve.pdf
The connection diagram is at:
http://www.goldenmotor.com/eBoat/HPM%20Drive%20Kit%20Setup.jpg
I believe that most of their motors are 9 pole 10 magnet (3 pairs), but I have not
found anything to support this.
Offline Chris2K
Re: 96V / 10KW
« Reply #3 on: August 29, 2013, 08:20:50 AM »
Thanks for trying to help. If somebody else has more information, please let me know. I think the motor runs a bit rough and I believe it is a result of the wrong pole pair setting.
