Author Topic: Bypassing the Battery Management System  (Read 29164 times)
Offline Scott Higgins
« on: May 16, 2013, 07:10:51 PM »
Anyone know how to bypass this type(4yr old GM) of BMS ?
Thanks Scott
Re: Bypassing the Battery Management System
« Reply #1 on: May 16, 2013, 11:35:22 PM »
I'm thinking of soldering a big honkin wire from D to B ?
Scott
« Reply #2 on: May 17, 2013, 06:32:01 PM »
Wouldn't unplugging the white plug do the same thing but
not do any permanent damage?
« Reply #3 on: May 17, 2013, 11:24:11 PM »
I will give it a try.
Thanks Scott
« Reply #4 on: May 17, 2013, 11:51:01 PM »
It is probably none of my business, but I'm a snoopy old fart.  Why do you want to not use the BMS?
« Reply #5 on: May 18, 2013, 12:46:50 AM »
Some of the cells are going south .So the bms kicks in to soon.This style of battery is real tough to replace the cells. Just trying to use'em till they drop.
Thanks Scott
« Reply #6 on: May 21, 2013, 03:20:46 PM »
Scott
Not sure if I would do that. Looks to me that would be a direct connection from positive to negative. I have bypassed the BMS on a few of those batteries. If you can wait a bit I'll look at how I did it and get back to this thread later today.
« Reply #7 on: May 21, 2013, 08:51:08 PM »
My understanding is that the battery is wired like the attached, and that the connector
mentioned earlier is labeled "to bms" in the picture.
Shorting across the BMS shorts across all the cells.
