Author Topic: Smart Pie Phase angle?  (Read 20540 times)
Offline Kris
« on: April 22, 2013, 11:16:29 PM »
I want to remove the internal controller from a smartpie so I can run the motor from a Kelly controller in order to have a play with variable regen. The Kelly controller config software is asking if the hall sensors are 60 or 120 degree. Does anybody know?
Re: Smart Pie Phase angle?
« Reply #1 on: April 23, 2013, 12:03:33 AM »
As far as I'm aware, all the GM hubmotors use the 120 degree setting in the GM software, I seem to recall that setting it to 60 degrees would force the older GM controllers to run only in sensorless mode (Pedal first).
Offline Kris
« Reply #2 on: April 24, 2013, 08:26:02 AM »
thank Al
