Author Topic: Question about MBG36F Mini Front Motor  (Read 22441 times)
Offline Dod
« on: April 10, 2013, 02:09:00 PM »
Hi, hello electric people im new here, this is my bicycle:
which im planning to convert in electric assisted.
so I want to know how easy is to wire MBG36F, 250W, since I have limited electric knowledge. im gonna build simple DC circuit with two 12v batteries connected in series, on off switch and this motor. if this motor has + and - wires connection im gonna be able to do it. I want to know before I buy it. I don't wanna buy something I can't wire :)
« Last Edit: April 10, 2013, 03:12:09 PM by Dod »
Re: Question about MBG36F Mini Front Motor
« Reply #1 on: April 10, 2013, 03:38:37 PM »
Hi Dod andto the forum.
I was unable to see the picture of your bike as the link does not appear to be working.
Unfortunately it's not quite as simple as connecting two wires from the motor to a battery. ???
This motor is a brushless motor and requires a separate speed controller to convert the constant DC battery voltage into a variable three phase AC output which powers the motor.
The motor has eight wires (three thick and five thin) that connect directly to the speed controller:
The controller connects to the battery with two thick wires, but also connects to the throttle, brake and cruise/horn switch (and also to the pedelec sensor and a horn if fitted).
Check out the wiring diagram.pdf for more information.
« Reply #2 on: April 10, 2013, 06:21:59 PM »
I'm seeing the link on my iPad. Maybe it's been corrected?
Hi Dod,
The wiring diagram does seem intimidating to some. If you want to see it step by step try this link.
http://goldenmotor.com/SMF/index.php?topic=3571.msg21344#msg21344
It is a Magic Pie 2 external hookup. But using the same controller. I think the only difference is you won't need reverse.
Offline Dod
« Reply #3 on: April 10, 2013, 09:01:30 PM »
thanks for replies really appreciate it. but I think im gonna give up this setup since everything become much more complicated then my initial idea. im gonna try some brushed DC motor setup.
