Author Topic: 60deg vs 120deg sensors configurations -> why both are needed?  (Read 23038 times)
Offline Just
Hi All,
As probably everyone knows, there are two configurations for hall sensors in the motor - 60deg vs 120deg. In both configurations the sensors are placed in the same places with the only difference so that the middle sensor is swapped in the 120deg config. If so then why both the config are needed?
Thank you!
