Author Topic: Motor is burned -> what does it mean?  (Read 44662 times)
Offline Just
« on: February 19, 2013, 03:42:53 PM »
Hi All,
Motor is burned -> what does it mean? What's exactly burned? Windings?
Thank you!
Offline MAGICPIE3FOCUSPOWER
Re: Motor is burned -> what does it mean?
« Reply #1 on: February 19, 2013, 05:33:38 PM »
Yes you are right :)
Offline Just
« Reply #2 on: February 19, 2013, 06:10:39 PM »
Hm... How could I test the windings in the Mid-Motor?
« Reply #3 on: February 19, 2013, 08:37:04 PM »
I dreally don't never donme before.
But can you open the motor and have a look at the windings?
Offline OzGeeksGarage
« Reply #4 on: February 19, 2013, 09:21:49 PM »
When the smoke or smell gets out of motors they're pretty much knackered, larger motors can be rewound if financially viable.
Please excuse my crappy typing, I'm partially blind
Offline Just
« Reply #5 on: February 19, 2013, 10:33:45 PM »
Thanks OzGeeksGarage! You are welcome!
« Reply #6 on: February 20, 2013, 03:28:10 AM »
How do you know the motor is burned. If it smelled bad it may be burned.  But it could be something else.
Offline Just
« Reply #7 on: February 20, 2013, 06:20:01 PM »
Could the windings been tested by just measuring the resistance between the phases?
« Reply #8 on: February 20, 2013, 11:03:30 PM »
They could be measured, you also need to do an insulation test at double the motors rated voltage too, you need to know what the readings are for a good motor, you can have windings short circuited or open circuited from overheating, but with 20 years experience as an electrician, once I open a motor up and smell it's burnt, even if it still works it's a good chance it won't work for very long. Your only chance is that there's something electronic inside burnt out if it has an inbuilt controller.
Offline Just
« Reply #9 on: February 23, 2013, 04:25:33 PM »
Why the Motors are burned? Due to over-current consumption? Are there other cases (besides getting water inside of the motor)?
« Reply #10 on: February 23, 2013, 07:22:05 PM »
Overcurrent = heat = burning.
Offline Just
« Reply #11 on: February 23, 2013, 07:24:21 PM »
Okay, so what's the protection?
« Reply #12 on: February 23, 2013, 10:04:34 PM »
Temperature sensor or current limit.
Offline Just
« Reply #13 on: February 23, 2013, 10:17:17 PM »
As for the temperature sensor, do you have one to recommend it?
« Reply #14 on: February 23, 2013, 10:27:17 PM »
What kind of controller do you have?
