Author Topic: What current does burn the motor -> peak or continuous?  (Read 45341 times)
Offline Just
« on: December 31, 2012, 07:43:01 PM »
Hi All,
Which current is more dangerous?
Are motors usually rated for the peak or continuous currents?
I have a 48V motor, which was rated by a manufacturer as a 350W one, but its controller is set to 17Amps for continuous current (48V*17A=816W) and to 22Amps for a peak current (48V*22A=1KW). How so?
Thank you!
Offline MAGICPIE3FOCUSPOWER
Re: What current does burn the motor -> peak or continuous?
« Reply #1 on: December 31, 2012, 08:01:35 PM »
Th only way to test when the motor will burn is testing by yourself hahaha :P
Peak is for short period and continuous....>>>it can handle the amps for long period.
Offline Just
« Reply #2 on: December 31, 2012, 09:47:38 PM »
So, what current is more dangerous? How much is possible to over-current the motor?
How much the motor can consume the current? Infinitely? Do the motors usually have some over-current ?????????? circuit or this is the controller's responsibility?
« Last Edit: December 31, 2012, 09:58:59 PM by just »
« Reply #3 on: December 31, 2012, 09:59:08 PM »
I don't know how much current is dangerous for a motor, it depends of the design of the motor.
So you should ask the maker.
Motor with thick windings/copper wires can comsumes more amps.
Normally motor don't have any current protection.
Well some of them have a temperature sensor for protection >>>>to much current >>>>more heat.
So the contoller is the brain for safe operation.
« Reply #4 on: December 31, 2012, 10:07:51 PM »
In geared motors  Nylon cogs can get mashed up with too much torque/amps pushing them.
Too much power through thin wires will cause heat/resistance and can make wires melt in the motor.
You can control amps with programable controllers and with cycle analysts. It all depends on what your battery can deliver.
« Last Edit: December 31, 2012, 10:13:42 PM by Andrew »
« Reply #5 on: December 31, 2012, 10:49:18 PM »
Waauww that's a nice feature controlling the amp.
I can d this while ridding?
Does it work with Kelly controller?
I don't a CA3, I have just a simple Turnigy wattmeter :-[
Offline Just
« Reply #6 on: December 31, 2012, 10:57:37 PM »
Yes, Kelly Controllers may work in two modes - Boost and Economic. As for the Economic mode, it's about 60% in the current limit of the Boost one. These modes are switchable during the ride.
Offline Lollandster
  • Norway
« Reply #7 on: January 01, 2013, 09:58:05 AM »
If you install a simple 10K NTC in the motor you can even have the CA3 limit the amps based on the temperature in the motor. This makes overwatting a bit safer.
With the latest firmware you can change power settings while riding.
Disclaimer: I know nothing.
My ebike Build blog
« Reply #8 on: January 01, 2013, 10:16:56 AM »
Aaha I didn't look at those features... :-[ While using the controller.... ;D
So I don't have buy the expensive CA3, just a simple switch 8)
Thanks!
Offline Just
« Reply #9 on: January 01, 2013, 10:22:47 AM »
What is the 10K NTC and what is CA3?
What Controller do you talking about?
Offline Just
« Reply #10 on: January 01, 2013, 10:25:06 AM »
How to use/install the 10K NTC thermistor into the motor? Do you have some instructions / guides how to do so?
« Reply #11 on: January 01, 2013, 10:26:54 AM »
Well it's quite simple, just install nearby the copper windings.
Offline Just
« Reply #12 on: January 01, 2013, 10:36:51 AM »
I'll try, thank you! Should the thermistors be connected to the Controller's pins directly without any additional components between them?
« Last Edit: January 01, 2013, 10:43:33 AM by just »
« Reply #13 on: January 01, 2013, 11:45:34 AM »
Yup just to the temperature sensor input pins.
Offline Just
« Reply #14 on: January 01, 2013, 12:07:04 PM »
Great! Thank you! I'll try! Would you recommend any specific NTC?
