Author Topic: Battery cut out at 43Volts. OK?  (Read 21974 times)
« on: June 14, 2012, 06:12:15 PM »
My LiFePo 48 V battery finally cut out at 43VDC.  Is this about normal?
The good thing is that I ran for several miles after my onboard volt meter indicated 48 VDC.  So I seem to have a pretty good indicator for range, as well as a little bit of reserve to get me home.
I'll charge it today and then I'll see what kind of range it gives.
Offline truly_bent
Re: Battery cut out at 43Volts. OK?
« Reply #1 on: June 14, 2012, 07:43:23 PM »
Good to know thanks. I haven't run mine out yet and i've been wondering when I could expect that. The presumption being that the BMS's in our packs are set for the same cutout voltage.
Offline skylinenitro
« Reply #2 on: June 15, 2012, 06:10:57 PM »
That sounds about right.  I ride Lead batts and it is horrendously slow and sluggish below 46 volts.  So when I get to 46 I always charge them back up.
I ran them down to 38 volts once, that was a bad idea.  The lights on the throttle stayed on but any attempt to use the throttle it would cut out right away.  After that ride I had a dead cell :(  btw I don't run a BMS on my bike, and I never let it get that low again.
Live Long and Prosper
