Author Topic: Testing regenrative breaking feature on the HPCX000 controller  (Read 22550 times)
Offline riwe
Hi all,
Has anyone been able to verify the voltage and amp seetings used during regenerative breaking on the HPC300 or 500 controller?
What I want to know is how stable is the voltage and amp when the motor, in this case a HPM5000B, is being rotated at a current RPM?
I have a setup with a I.C.E, internal combustion engine and a PMAC motor. The PMAC acts as both a motor and a generator. When the I.C.E is running the PMAC acts a a generator and recharges the battery bank.
Since I am using a 48V system with Lifepo4 batteries the voltage generated must not exceed 58.4Volt. The Amp can be up to 90A.
Has anyone tried this? Does anyone have a setup with two HPC controller and two motors to try this?
Best regards
Rikard
