Author Topic: Connect PAS to Dual Piant?  (Read 21084 times)
Offline CamiloChile
« on: November 29, 2011, 09:19:36 PM »
i wanna connect a PAS to my giant dual piant, how I can connect this?
Re: Connect PAS to Dual Piant?
« Reply #1 on: November 30, 2011, 01:16:15 AM »
It should hopefully be as simple as connecting the pedelec unit to one motor and then linking the signal wire to the other motor's pedelec connector.
Check out the wiring diagram in this post which shows how to connect it.
You'll need to make sure that the direction is programmed the same for both motors, or it might activate one motor when pedalling forwards, and the other when pedalling backwards. :o
Unfortunately, I don't recall dual pedelec ever being tried by anyone on the forum yet, so perhaps you can let use know if it works correctly.
Offline CamiloChile
« Reply #2 on: December 09, 2011, 02:33:21 PM »
connect the PAS is VERY EASY, only you need find the signal of PAS and connect between the two's signals together, later connect the red wire of PAS in the red wire of throttle (+5v) and the negative in the wire common
regars
