Author Topic: I challenge Golden Motor to make the world's best BLDC Hub Motor and Controller  (Read 46571 times)
Offline Who42
  • ELECTRIC BIKE NUT
    • PLUG IN CARS & BIKES
I CHALLENGE GOLDEN MOTOR TO MAKE THE WORLDS BEST BLDC HUB MOTOR and CONTROLLER :o
At an affordable Price 8)
The combination of these two can drive a vehicle of 140kg + driver to over 120km/h at 1200W
So Golden Motor LOOK and Reserch how they did this and make your own version  :o
TRITIUM :The WaveSculptor22 motor drive is a high efficiency, low weight, three phase 20kW variable frequency inverter especially designed to drive high efficiency, low inductance, permanent magnet motors.
Specifications
Peak Power Rating 20kW
Average Power Rating Dependent on cooling solution provided: up to 20kW with water cooling
Motor Type Three-phase permanent magnet (BLDC) or Induction
Cruise Efficiency 99.2%
Cooling Method Cold plate (controller will self-limit temperature if necessary)
Environmental Rating IP42
Maximum Battery Voltage 160V DC
Maximum Motor Current 100Amps
Output Waveform Sinusoid
Communications CAN bus
Dimensions 255 x 165 x 35mm
Mass 855g
 LINK: http://www.tritium.com.au/products/TRI88/index.html
In-wheel motor for solar-powered electric vehicles: technical details
Download the technical and pricing details for CSIRO’s in-wheel BLDC motor design, which is widely accepted as the most efficient BLDC motor ever made at around 98% EFF.
LINK: http://www.csiro.au/resources/pf11g.html
LINK TO PDF file  http://www.ata.org.au/wp-content/uploads/marand_high_efficiency_motor.pdf
« Last Edit: October 14, 2011, 01:04:36 PM by Who42 »
ELECTRIC BIKE NUT
Yeah the csiro motors are Ironless axial motors. Great development and IMO it's only the "in-between-results", on load and without load is there room for any improvement.   To build takes 40 hours to wind.
Those specs are going to be difficult to achieve on a normal bike in any case due to wind resistances, with the Iron motor one could expect some losses on say an MP due to the iron losses and stray EM with eddy currents.
The beauty with the axial designs is they make most of the projected EM from the core and work on a semi toroid effect around the stator to increase inductance per wind , this decreases the EM foot print allowing sharp focus upon the permanent-magent rings on either sides of the stator.
IMO is youre using ceramic, an interesting idea to play with is to use an Iron powderd core, semi iron cores, even a fairy sprinkle of iron will increase inductance, anything that can gain reactance will allow one to decrease winding resistance further, hopfully without losing too much in the core, this just may sqeeze a little more out of the axial designs for the mainstream legal bike motor market. Required voltages over 48v are not desirable so lowering winding resistance and getting as much reactance/voltage/resistance is crucial.
The CSRIO motors measured up to 95-98% efficiency.  This was aided by a very low resistance over the controller fets and careful PWM current limiting control, ommiting shunts where possible, ultra low mechanical resistance and very good aero dynamics wheel and tire designs..  The less mechanical and external resistance one can place upon a motor, the better the all round results.  Even the weight of the motor chasis, and spokes reaction to wind resistance will lose you some points on efficiency in some tests.
Now with the speed 1200 watts @ 120 km/h, A man can peddal a bike @ 130kph, and reason this is, is the bike has extremely good aero dynamics.
That said, an MP probably with the right voltages and most importantly on the right bike and controller could push that speed using + 10%-15% power. Maybe even 1500-1600 watts.
http://www.youtube.com/watch?v=jQwpGLCAMm4&feature=fvwrel
If that guy can pedal 132 kph imagine if he had some high voltage motor assistance? :P
Anyway nice challenge, and I think if anyone can make these designs available to the mainstream it will be the chinese.
BTW GM already have a pancake motor.  Havent been here for a year now so I'm not sure if the still have them available. Not sure about it's performances.
A tweaked, software current controlled, no shunt , high voltage, with a larger low internal restance LI battery may just get you up to 90% effieciency.  That's getting closer.
« Last Edit: October 14, 2011, 10:33:59 PM by Les »
Les, you forgot to show the video with the next run :)
YouTube Link
Bwahahah.  I never saw that one.
But this one usually makes my eyes water.
http://www.youtube.com/watch?v=JLRDRzMWIsg
And this one.
http://www.youtube.com/watch?v=4oCGe3HNty8
CRACKS ME UP.  Sounds like storm troopers..  I think the audio was defucnt on purpouse, he looked like he was roasting the dude in front.
And this one.
Les, I must say it is most refreshing having you back on the forum!!! Lol not that much has changed ;) hehe!
Hahaha
That second one definatly got a laugh out of me :)
Hahaha
LOL I know the guy was like (in storm trooper radio) "Ohhhhh you freaking idiot!!! Why did you stop there?? And right in the middle???? You idiotttttttttttt
And the other guy was like "ohhh nahh I thought you were way further back, its your fault man you should have braked
None of them would own up haha it was gold
It was for sure the guy who stopped, who does that in such a narrow area?? haha
