Author Topic: rad2go Q chariot....General question...Pleeeeeeeease help....  (Read 23316 times)
Offline shacketj
« on: November 10, 2008, 10:58:06 PM »
PLEEEEEASE help...
I picked up a scooter from my neighbor and thought it would be a quick fix to get it up and running.
36V, two 180W hub motors with new batteries and brakes.
When I replaced the batteries and connected it all together, the wheels just started spinning even with the key in the "off" position.  I checked all the connections and everything seemed right.  I talked to a shop and was told that I needed to replace the motor controller.
After hours searching, I found the speed/volt controller (LBD14 or YK40), but still need to find the "brain" that connects to the two motors.  I can find a million parts that connect to a single motor, but nothing with two connectors...
Help...
Offline fbvisitor
Re: rad2go Q chariot....General question...Pleeeeeeeease help....
« Reply #1 on: November 13, 2008, 11:55:09 PM »
How about a few pictures.
I'm sure one the many helpful people who drop by this forum will have a better idea of what the problem is when they see it.
Cheers.
Offline TOM
« Reply #2 on: November 17, 2008, 08:47:22 AM »
from 180w,I think  your motor controller must 24V,
when you put through 36V voltage,
24V motor controller must be broken
I have met before.
