Author Topic: Electric Motorcycle Conversion Kit  (Read 107446 times)
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« on: September 24, 2011, 05:27:39 AM »
It becomes easier to convert existing gasline motorcycles into electric with Golden Motor's 3-20KW brushless motors and controllers.
« Last Edit: September 24, 2011, 10:10:14 AM by GoldenMotor »
Offline Kittuk4ever@gmail.com
Re: Electric Motorcycle Conversion Kit
« Reply #1 on: December 06, 2011, 04:24:45 PM »
what is it's top speed???
« Reply #2 on: December 06, 2011, 04:30:48 PM »
i'm using the hpm 5000b 72v motor and six 12v 26ah lifepo4 batteries and i'm using them for a electric motorcycle conversion......the dry weight of the motorcycle is 45 kilograms (excluding the motor and batteries and controller) can someone tell me what can be the top speed of the motorcycle????????????????????????? ???
« Reply #3 on: December 07, 2011, 06:17:39 AM »
It's not that easy.
At 80V The motor will supply 9kW -200A @ 7000rpm.
The top speed will depend on your
gear ratio and load.
7000 * t1/t2 * 2pi * r
t1: teeth on drive
t2: rear sprocket
r: radius of rear wheel
That gives you inches per min.
(or cm power min.) if you can
pull that much power.
Offline gingerbreadman
« Reply #4 on: December 29, 2011, 05:02:10 PM »
Anyone have try to convert a sach madass 125cc to electric?
« Reply #5 on: December 30, 2011, 10:20:07 AM »
Have not seen it in this forum... But would be excellent to do, providing you knocked up some custom battery mounts. I can see 15Ah either side of the frame and a fat torque converter linked to the BLDC chain/belt drive
That would be awesome to ride
Hmmmm good idea lol
« Reply #6 on: April 30, 2012, 02:02:05 PM »
but im fixing the motor inside a custom made hub
