Author Topic: So close need help  (Read 27609 times)
Offline fearlessfostick
So close need help
« on: April 22, 2011, 03:23:15 AM »
Tested out the connections last night, power was on full, I gave the throttle a little turn and felt the bike lurch.  I went to try it again tonight.  Power was on full, horn works, tested the throttle, the bike motor starts to grab, shudders then nothing, the controller beeps twice.  Nothing happens after that, I still have full power.  Any ideas on what this could be?
Offline Sangesf
Re: So close need help
« Reply #1 on: April 22, 2011, 04:11:27 AM »
2 beeps usually means hall sensor malfunction...  Either the hall sensor connectors have a problem or one of the hall sensors in the motor failed.
What kind of motor is it?
Try moving the bike about 3 feet while turning the throttle...
The two beeps made it go into sensorless mode and as long as you don't have a mini motor, the bike should run fine, just as long as you move it forward first.
« Reply #2 on: April 22, 2011, 04:55:28 AM »
Rear 48 volt 1000 watt motor (not Magic Pie)
« Reply #3 on: April 22, 2011, 10:48:33 AM »
As Frank has already said, you appear to have a problem with either the hall sensors or one of their connections.  Double check that the hall sensor connections are properly connected at the motor connection and the controller end.
Take a look at this post and this video for more details on testing the operation of the hall sensors.
« Reply #4 on: April 22, 2011, 01:30:22 PM »
Thanks, what is the function of the hall sensors?
Offline krelle52
« Reply #5 on: April 22, 2011, 05:21:45 PM »
Positioning and maybe speed detection, I'm not sure whether they also use them for that
Wikipedia (and Goolge) is your friend ;)
http://en.wikipedia.org/wiki/Hall_effect_sensor
/Krelle52
