Author Topic: Anyone played around with flat GM battery cells?  (Read 27506 times)
Offline Cornelius
  • Grimstad, Norway
« on: March 14, 2011, 09:11:51 AM »
I've just opened and started disassemly of my brothers old 36V16Ah GM battery, which has been beneath a pile of snow a whole winter, and just lying around for a whole another year... :o
The BMS are ofcourse badly corroded, but the cells aren't that bad - visually... ;) Measuring each bank of 4 cells gives 1 bank of 2.6V, 2 banks of 3.5V - and 7 banks of 0.0V  ;D The 3 banks with actual voltage should be ok.
Having a lab. power supply delivering up to 24V@2.5A, I started charging 5 banks in series for 20 minutes and let the batteries rest for 1/2 hour. after that, 3 of the banks had 2-3 cells still hot to the touch. I'm guessing those cells was being drained by a shorted cell in the same bank. Those 3 banks measured around 0.8V at that time. The other 2 banks fell rapidly down to 0.0V...
Now I've disassembled each bank, and started charging single cells at 4.22V@4A.
So far, I've got 5 cells that keeps 4.00V at rest 2 hours after charging. (I'm keeping a manual eye on the voltageduring charge.) As soon the voltage reaches 4.220V (high precision Fluke meter), I stop the charge.
I haven't started charging those 3 banks that had 2.5V++ volts initially yet; believing those are ok.
Anyone have any experience regarding life reduction of these cells being totally flat for a period of time?
« Last Edit: March 14, 2011, 09:15:31 AM by Cornelius »
Re: Anyone played around with flat GM battery cells?
« Reply #1 on: March 14, 2011, 10:03:51 AM »
I have noticed that really bad cells will start holding voltage, but in a short space of time will drop voltage, then it will drag the voltage of the entire pack down....
you could charge them up and try some load testing....
Offline Cornelius
  • Grimstad, Norway
« Reply #2 on: March 14, 2011, 10:24:01 AM »
You're probably right...
I've reduced the charging Amp to 2A because of the heat the cells developed @4A charge. Some of the cells i've charged so far, reached 4.20V in just 1 hour @ 2A, and that tells us the capacity are significantly reduced.
I'm thinking of using an PicAxe 08M to build a single cell charger that monitors voltage and temperature, and controls the charging output on/off; with logging to pc... That way, I have better control over time used to charge, and since charging current are rather constant until around 4.1V, capacity gained are easily calculated. :)
Offline Cornelius
  • Grimstad, Norway
« Reply #3 on: March 14, 2011, 11:26:24 AM »
I just browsed around the net and found some useful info at batteryuniversity.com :
Do not recharge lithium-ion if a cell has stayed at or below 1.5V for more than a week. Copper shunts may have formed inside the cells that can lead to a partial or total electrical short. If recharged, the cells might become unstable, causing excessive heat or showing other anomalies. Li-ion packs that have been under stress are more sensitive to mechanical abuse, such as vibration, dropping and exposure to heat.
Another one:
Charge efficiency is 97 to 99 percent and the cell remains cool during charge.
In other words; when i'm playing at charging these 0.0V cells, and see that they're getting hot rather quick, I should really just throw them away... :P
And finally, some guidelines:
•A portable device should be turned off while charging. This allows the battery to reach the threshold voltage unhindered and reflects the correct saturation current responsible to terminate the charge. A parasitic load confuses the charger.
•Charge at a moderate temperature. Do not charge below freezing.
•Lithium-ion does not need to be fully charged; a partial charge is better.
•Chargers use different methods for “ready” indication. The light signal may not always indicate a full charge.
•Discontinue using charger and/or battery if the battery gets excessively warm.
•Before prolonged storage, apply some charge to bring the pack to about half charge.
•Over-discharged batteries can be “boosted” to life again. Discard pack if the voltage does not rise to a normal level within a minute while on boost.
Now, we're a bit wiser... ;D
