Author Topic: simple question about 36v motor/controller compatability with 48v battery?  (Read 25604 times)
Offline Sv37
Hello,
If I have a 36v 500w motor with a 36v motor controller (some cheapo controller that I don't have much info on), will I be able to run off a 48v battery (for higher speeds) or would it damage something?
Re: simple question about 36v motor/controller compatability with 48v battery?
« Reply #1 on: December 01, 2010, 03:08:51 PM »
The motor should be able to cope with the higher voltage, just so long as you don't overload it too much, but if the controller is not built for 48V use it could fail when fed with a 48V pack.
