Author Topic: TWIN PIES  (Read 29375 times)
Offline Rob9771
TWIN PIES
« on: September 26, 2010, 02:57:33 PM »
HI
Having had one Pie pack up I am considering going for two on the basis that at least I can still get home without having to manually pedal a 60lb bike !
Does anyone know whether the two will run happily together from one battery and whether I would need extra battery power. I am running 1000w 48 v
on the rear but with the battery it has really messed up the handling. At least with a front hub although heavier it should be better balanced.
Appreciate any guidance
Rob
Re: TWIN PIES
« Reply #1 on: September 26, 2010, 04:19:46 PM »
Hey do it for sure,
It's great with the extra weight in the front for handling, and will run fine off a GM 48v 12Ah
Make sure you set both wheels to 24v with the USB cable ;)
The range is the same if not better because they don't work nearly as hard uphill. Anyways well worth the extra $$$
cheers
Offline Rob9771
Re: TWIN PIES
« Reply #2 on: September 27, 2010, 09:13:14 AM »
Hi
How simple is it to connect the second motor to the wiring ?
Rob
Re: TWIN PIES
« Reply #3 on: September 27, 2010, 03:47:57 PM »
Rob, check out Leslie's diagram:
