Author Topic: 2 Beeps when hub moves but no power  (Read 112222 times)
Offline cagatay
Re: 2 Beeps when hub moves but no power
« Reply #30 on: February 13, 2011, 01:05:10 PM »
     Hi
  I  have same problem like you but I do not use throttle I try to drive my gm 5k pot. when I give power to controller I hear 2 beeps and no work my hub.
    could you help me?
« Last Edit: February 13, 2011, 01:19:32 PM by Bikemad »
« Reply #31 on: February 13, 2011, 01:27:46 PM »
Hi Cagatay andto the forum.
Two beeps usually indicates failure of the hall sensors inside the motor, if you can give us a bit more information it might help:
Which motor do you have?
How old is it?
Did it work OK before, and has recently stopped working, or has it never worked at all?
Have you tried spinning the wheel to see if it then starts to run under its own power?
« Last Edit: June 30, 2017, 09:28:10 PM by Bikemad »
Offline cagatay
« Reply #32 on: March 01, 2011, 04:56:41 PM »
  hi
   ? have 36 v 250 watt rear motor and it is almost 4 months old. it worked before a lott before but now not ? have ordered a throttle ? am expecting my throttle when it comes ? will try again.
 I have not tried spin wheel also.
   can that be any problem about motor hall effect sensor?
   thanks your reply...
Offline Just
Re: 2 Beeps when hub moves but no power [URGENT]
« Reply #33 on: April 11, 2011, 10:56:05 AM »
I have the same problem - two beeps on connection the battery to the controller. Actually these are only two wires connected to the controllers and these wires are from the battery...
What's wrong? How the problem might be solved? What're next steps?
Thank you
