Author Topic: does 4 year old brushless motor work with new cruise controller?  (Read 23306 times)
Offline tex tiles
I have a kit on my bike that is an older version with a brushless motor. My throttle died and I decided to buy a new controller with the cruise control at the same time. Is my 4 year old brushless motor compatible with the new controller? (I hope so because I already bought it.) Any suggestions to the hookup?
Thanks, Pete
Offline GM Brazil
Re: does 4 year old brushless motor work with new cruise controller?
« Reply #1 on: August 30, 2010, 11:51:54 PM »
Any specs?
Voltage
Power
Model
Battery used with it
Etc. :D
« Reply #2 on: August 31, 2010, 02:43:48 AM »
As long as your older motor is
a sensored brushless motor
(3 power plus 5 hall sensor wires)
then the magic controller will work fine.
I hope you took the trouble to get the one that
is configured for your wheel power rating.
A 1000W controller on a 500W wheel is just asking for
overheating.
Offline tex tiles
« Reply #3 on: August 31, 2010, 05:50:35 AM »
Here is a picture of the motor and the controller. The motor is 36 volt, I believe 500 watts. The controller is the current GM model. I don't know how many watts the controller is. My battery is a GM lithium 16 amp 36 volt.
« Last Edit: September 02, 2010, 12:29:42 AM by tex tiles »
Offline TOM
« Reply #4 on: September 02, 2010, 08:24:20 AM »
The phase  of your motor must be 120°,then it can easy to match with our cruise controller.
